dvd movie only, to 1 dvd-r
1)Rip the movie files (if they fit) with dvd decrypter (FILE MODE)
2)open ifo file with ifo edit
3)click vob extras--click ONLY corect vob-unit, corect ifo tables and create new video_ts.ifo & vts_01_0.ifo
4)when done close ifoedit. Delete old folder. Keep new folder (with new vob's and ifo's)
5)open ifo edit, open ifo, get vts sectors.
DONE!!!! READY TO BURN YOUR DVD (15 minutes procedure)
dvd movie only, to 2 dvd-r
1)Rip the half movie files (if they fit) with dvd decrypter (IFO MODE)
2)the rest of the procedure is the same as above
3)do the same thing with the rest half movie files.
In few words...in ifo edit treat them like seperate movies
That's all.....hope i helped a little!!!
Thread: Easy....Soooooo easy guide
What about Strip stream's and Strip vobid's?Originally Posted by strangezero
This is very usefull to make a 4.4-to-5.2GB movie to be stripped
down to the maximum 4.39GB for one 1DVDR.
Yeap you can do that also. ....This is the easiest way to copy dvd's
And you have Subtitles and rest
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 04:44 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 11:57 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 08:07 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
VDubMod & logoaway-Easy Guide-but 22hrs to process????????
By thegeeman in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 09:20
Statistics
Newest guides
Latest tool updates
New media comments
