I here this term used all the time what is macrovision?
- Tank
Thread: Macrovision??
Marcovision
It's a form of copy protection. Comes in many forms as well like, brightness fluctuation, vertical sync hold. VHS tapes and DVD have it on them. All new VCR have a circuit to detect it and prevent you from copying the movie.May the force be with you.
If you rip a dvd, the macrovision is removed. There are some DVD players that you can hack to remove macrovision from their outputs if you want to capture analog outputs.
You can also use a "video stabilizer" which are fairly inexpensive ($50). These can be battery operated and you just put them inline with the composite video signal. These will work with DVD and VHS players.
Macrovision Question
By matthewjohn23 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 7th Jun 2011, 15:19 -
Macrovision like NONE OTHER
By blacksheepdownunder in forum CapturingReplies: 17Last Post: 22nd Jul 2010, 04:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 16:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 20:41 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 10:37
Statistics
Newest guides
Latest tool updates
New media comments
