VideoHelp.com Forum
    I have a Casio BE300 pocket manager. It's capable of playing Vcds. but them must be compressed to a vcd format, Does anyone have a template for tmpeg to do this?
    TMPGenc has a VCD template... there is only one NTSC VCD specification so you can read up on this in the 'encode' guides on the left.
    Be careful that they really mean VCD-spec files because your wording suggests an uncommon format (while VCD is extremely common).
    I was reading at other websites, that sugested that the video should be re-converted from a Vcd format to different settings.
    example 320 x 240 30fps 64 kbits,
    I know thats not a vcd standard but "from" the vcd standard to a file that takes up aprox 4 megs per 1 minute of video is my goal. with good picture quality on the personal organizer.
    I was looking for a template if someone was successfull in creating one.
    I really don't care what the settings are as long as they work and don't take up a ton of space, because memory is limited
  1. playing looped video clip from pocket projector
    By josefin in forum Portable Video
    Last Post: 25th Jan 2011, 18:53
  2. Help please, easy format pocket camcorder?
    By Lilygrace in forum Newbie / General discussions
    Last Post: 23rd Aug 2010, 12:04
  3. safe few bucks from my pocket
    By mrdin2005 in forum Video Streaming
    Last Post: 20th Jul 2009, 04:26
  4. Fujitsu Siemens Pocket LOOX
    By mgowins in forum Video Conversion
    Last Post: 9th Jul 2009, 16:09
  5. Movie player for Pocket PC??
    By Cazz in forum Software Playing
    Last Post: 2nd Jul 2009, 15:39
