Ok, hi all!
I didn't know exactly where to post this topic so just put it there!
I search through this forum about hardware requirements but found various replies and some are discordants.
So i would like to ask this question, regarding the fact i intend to buy a new comp.
I know 2 peoples with similar configuration: Athlon XP 1800, 256 MO DDR and XP 1800 512 DDR.
It seems that the 512 Mo DDR encode vob to divx in around 3.5 hours for a 2 pass with vdub as it takes around 5-6 hours for the 256 DDR. So basically, it means the more memory you have, the faster it goes... but!
I was just wondering if it so true! I mean i can easily understand that at , some point memory can increase the speed in the way it bring data to the cpu but i suppose there's a limit! Considering this, could someone can reply to this following questions?
- For a XP 2200, what would be the best bet in term of memory? is 512 DDR enough? Will be there a big difference than with 1024?
- does the same pattern apply for the various process like ripping/encoding to divx, to vcd or svcd?
- does someone has a kind of grphic that show the best rate between CPU/Memory?
Moreover, if someone could correct this enumeration...
Divx encoding: it use max memory / max cpu
(S)VCD encoding from Divx: average memory / max cpu
SVCD encoding from Vob: average memory / max cpu
thanks for the reply
Aguirre
Results 1 to 1 of 1
Thread: Hardware requirement and thought
Convert from MKV to TS file with subtitle and these requirement
By kucku in forum Video ConversionReplies: 1Last Post: 15th Jun 2011, 21:25 -
H.264 MOV Requirement
By NautTboy in forum Software PlayingReplies: 3Last Post: 14th May 2010, 18:55 -
Newbie ?: SDHC requirement and HD recording
By carlsjunior99 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 30th Mar 2010, 15:45 -
system requirement for x264
By Shaorin in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 01:18
