    Hi all.
    Hope somebody can help me with this one.
    1. I capture video to an AVI file using UYVY, YUY2, or huffyuv;
    2. I run it through VirtualDub to apply some filters (any filters);
    3. I Save the file to a new AVI file (uncompressed RGB or huffyuv);
    The resulting file is about 50% larger than the original and stutters like mad when I play it (using a number of players). The stuttering is so strong that the film seems like a disjoint series of frames rather than a video stream...
    If I try to encode the resulting AVI to mpeg (using any of a number of encoders) the stuttering passes through to the final result.
    I can frameserve from VDub to other software. If I simply use this other software (like Tmpgenc) to save to an AVI, the odd size and stuttering pass through. If I use this other software to encode to mpeg, it works fine. But frameserving is a bad option if you're doing multiple pass vbr, so I really am looking for a solution to saving the AVI file first and then encoding it.
    I have a dual boot system. Same problems happen under W98 and W2K.
    Has ANYBODY seen anything like this?
    rgds
    Eduardo
  2. When you save to a new avi file, you ought to re-use the same codecs you used for capturing or some editing codec...huffyuv captures reduces 50% of filesize lossless, so if you save it uncompressed...naturally...it will be much larger...
  1. Replies: 3
    Last Post: 4th Nov 2009, 21:20
  2. Saved file size after VirtualDub
    By Mean-Hippy in forum Newbie / General discussions
    Last Post: 1st Oct 2006, 19:34
  3. Output file saved larger than 4.37?
    By cannew in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Aug 2005, 17:33
  4. virtualdub creates substantially larger avi
    By syeager in forum Editing
    Last Post: 7th Oct 2004, 10:14
  5. Replies: 4
    Last Post: 26th Apr 2002, 03:00
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
