Hi, i tried to convert DAT file into MPEG but when I burn on DVD and run on TV the quality wasn't good. Is ther better way to do this?![]()
Thread: Converting DAT file into MPEG
Burning on dvd doesn't mean that the quality will improve, garbage in - garbage out. And please explain exactly what you are trying to do.
If you want dvd quality it needs to be a dvd rip
Thanks for ur response
I've some movies & songs in DAT format.......to keep the Quality as same I want to convert in DVD...so I don't want garbage in and out
Is there any way i keep the same quality.any software Once again thanks for ur resposne.
tom
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
Statistics
Newest guides
Latest tool updates
New media comments
