VideoHelp.com Forum
Thread: Video Tearing
    I did a capture from Tivo and got a great looking (if large) avi file. When I converted to mpg with TMPGEnc, I got excessive video tearing around moving objects, sort of a venetian blind effect.
    Since it was only around moving objects, I'm guessing the error stems from some mpg conversion artifact, but I'm at a loss to trouble shoot this problem.
    Has anyone experienced this and found a way around it?
    Thanks.
    Sounds like Interlacing. Is this an mperg-1 or mpeg-2 file? What is your final destination going to be? VCD, SVCD or DVD?
    May the force be with you.
    It's an mpeg 1 file and I'm using the presets for VCD. Do you know how I adjust the interlacing?
    Thanks!
    You need to deinterlace it. You can use tmpegenc to deinterlace it. settings>advance then double click deinterlace and choose the method. I use the even field method.
  1. Horizontal Tearing
    By Tripledrop in forum Software Playing
    Last Post: 16th Mar 2011, 12:57
  2. Replies: 14
    Last Post: 21st Oct 2010, 05:55
  3. Replies: 8
    Last Post: 14th Sep 2010, 03:40
  4. Replies: 0
    Last Post: 29th Oct 2009, 09:53
  5. Frame tearing with PC playback
    By Twist in forum Media Center PC / MediaCenters
    Last Post: 26th Feb 2008, 10:46
