I created a SVCD and in the beginning of the movie it has perfect sync but near the end of movie the sound becomes out of sync. The audio is offset by 1.5 secs. Any help is greatly appreciated. Thanks
less than jake, wooo hooo!!!!!
this out of sync question was "answered" earlier, sometimes movies will have more than one framerate throughout the entire movie, so if the framerate changes like that and you dont decode to quicktime movie first (without specifying any framerate) you run the risk of the movie going out of sync (from what i hear) its a bitch
mpeg2decX has a variable frame rate option. I heard it should be able to take care of that kind of problem.
http://homepage1.nifty.com/~toku/software_en.html
How in the hell can movie have variable framerate, when shown on TV?
Same problem applies for me, when recording live TV-shows too. No sync problems, when recording to DVD, but terrible gradual unsync, when making SVCD even from same recording.
Have PVR-250 and have used Ulead DVD MF, DVD WS, nanocosmos, TMPG, BBmpeg. Nothing helps. Only re-encoding in DVD MF into SVCD compliant and then burning in nero instead of MF seemed to give good results. TMPG and BB remuxes are outsync allready on PC.
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 17:43 -
Fix .mov where A/V in sync at beginning, ~1 sec offset at end?
By Grahamf in forum ffmpegX general discussionReplies: 3Last Post: 30th Mar 2011, 12:14 -
editing video - cutting a few minutes at the beginning and end
By Ally68 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2010, 17:19 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
automatically cut out beginning & end of a video
By ari.kulmala in forum EditingReplies: 1Last Post: 25th Aug 2009, 15:44
Statistics
Newest guides
Latest tool updates
New media comments
