My Pioneer DV-344 DVD player's manual says I can change NTSC playback to PAL (and vice versa). I followed the procedure in the manual that lets you set the signal playback of your choice. But the problem is: say I want to play an NTSC DVD as PAL, so I follow the procedure to set the DVD player to play as PAL and the word 'PAL' appears on the display window. But when I load an NTSC disc and start playing it, it plays in it's original NTSC signal instead of PAL.
The same problem happens if I want to play a PAL DVD as NTSC -- I set the signal playback on my DVD player to NTSC, but when a PAL disc is inserted and loaded, it's played in it's original PAL signal instead of NTSC.
What's the problem here?
For the record, the method used to set signal playback is: switch the DVD player into standby. Then hold down the Forward button on the player itself and press the Standby/On button on the player itself. You do this until either PAL or NTSC appears on the display window.
Results 1 to 1 of 1
WDTV - Mkv Ntsc files (on a Pal Machine) Playback Problem
By billybob2007 in forum Media Center PC / MediaCentersReplies: 15Last Post: 26th Sep 2011, 10:36 -
PAL video on NTSC HD TV Best motion Playback
By Deter in forum RestorationReplies: 7Last Post: 25th Aug 2011, 05:34 -
NTSC -> PAL on NTSC Playback VCR
By Cyberrock in forum CapturingReplies: 21Last Post: 28th Sep 2010, 03:52 -
Can the JVC HR-DVS1 playback both NTSC and PAL videos
By ramrod1234 in forum CapturingReplies: 7Last Post: 11th Oct 2009, 09:43 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47
