VideoHelp.com Forum
  1. Hi,
    I have an AVI am trying to convert to SVCD. The problem is that the avi has sound out of the left speaker only (even though it appears to be a stereo track).
    I need a way to convert the left speaker output to a mono wav, then convert the new mono wav to stereo, with the same sound from both speakers... so I can then insert back into the avi and convert to svcd....
    Any idea's of a program I could use? (I am using Graphedit to remove the wav from the avi, Virtualdub to add it back in, and tmpgenc to convert to svcd).
    Thanks guys
    Palleon
    You could load the original video in Gold Wave. Select the audio channel with the audio, copy it. Select the audio channel with the missing audio, Mix it with your copied audio. Save. Use TMPGEnc to Mux it back together.
    Hello.
  1. Mono / Stereo sound
    By rogierweb in forum Audio
    Last Post: 13th Nov 2011, 19:09
  2. mono headphone mod to get stereo sound
    By snafubaby in forum Audio
    Last Post: 5th Jun 2011, 19:54
  3. Mono to Stereo? (AVI/DIVX)
    By slow_rider in forum Audio
    Last Post: 21st Oct 2009, 06:44
  4. HI8->DVD mono sound to stereo fix
    By Ligr in forum Newbie / General discussions
    Last Post: 15th Jul 2009, 16:58
  5. Stereo AVI gets converted to double mono using L channel while transcoding
    By AppliedCD in forum Newbie / General discussions
    Last Post: 16th Aug 2007, 22:38
