Has anyone tried these discs?
9.4GB DVD-R General Purpose "Double-Sided" in Jewel Cases 25, 50, 100 Pack, As Low As $2.60 Each
http://store.yahoo.com/cdrdvdrmedia/94dvgenpurdo.html
They're your run of the mill generic DVD-R's. 1x burn on AO3 (1.90 firmware)
I've tested them in Apex players (AD500, 500W, 1100, 1500, 5131, 660, 703). Works in PS2. Didn't play corectly in Emerson (VHS + DVD), nor 2 Toshiba's (haven't gotten any media to play correctly in those palyers though).
Then again Pioneer, TDK, Mitsui media didn't work in the Emerson, or the Toshiba's.
Anything that plays Princo or Ritek media will play these.
ADVDInfo
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 37 0E 0B .B...@....P..7..
FE FF 80 00 03 52 49 54 45 4B 47 00 04 30 33 00 .....RITEKG..03
Use Neato's core labels to label the center of the disc.
Too expensive / capacity. I used those with good results when it was worthwhile to buy one double instead of 2 1 sided discs. Now 1 sided discs are about 90c/each, while those are $2.6. To be worthwhile, they would need to be about $1.8.
They work well otherwise with the Pioneer A03 and Apex or Raite players.
These work very well as I have used tons of them. They are more expensive (per side) as dragan said but for me it is woth it. It is basically a convenience issue as to wether or not you want 2 or 1 disc to contain large movies.
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 13:01 -
Is there such a thing as "DVD-RW 4X Double Layer 8.5G"???????
By will7370 in forum MediaReplies: 2Last Post: 3rd Jun 2009, 17:04 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
Statistics
Newest guides
Latest tool updates
New media comments
