Hi, i'm curious if anyone has had this problem.
I've used the VCD Header Trick on numerous occasions to get a specific DVD player to play my SVCDs. I've never had this happen before.
For some reason, on one particular disc, which is no longer than any others, when i do the header trick i get an .mpg file which shows up as much larger than the 80 AND 90 min boundary in Nero.
I have followed the same procedure as usual whihc included:
1) simple de-multiplex the svcd
2) simple multiplex with MPEG 1 VCD header.
why is this giving me a really long mpg? has anyone seen this before?
Yep, I see it all the time.
It usually happens to me when I'm trying to fake a VCD from a one-cd SVCD. Something about the vbr, I don't know.
You can try to simple-multiplex to VCD non-standard. It produced, to me, a file approximately the same size, but I had a/v desync when I tried to play it on my standalone. Maybe you'll get more lucky...
I also tried to multiplex the mpeg2 video and the audio as VCD in bbmpeg, but the image kept "jumping" and them froze when played.
see this is weird...
last week i did this with no problem... now this week i just tried it with the exact same svcd mpg file and this time it's giving me the superlong vcd which nero won't burn.
i have question...
when doing the header trick is it neccesary to de-multiplex then multiplex? or is it sufficient to just run the file thourhg simple multiplex?
ok, i think i have it sorted out...
it's working now. although i am still doing the same procedure.
here's my guess on what went wrong.
my source .mpg (svcd) file that i am using is mounted in a bin/cue using daemon tools. when i switched the mounting i did not unmount the old cd image, and i think that's what was screwing it up. i just unmounted the old file in dameon tools before mounting a new file and this time it worked. so my assumption is that my source file was screwy.
thanks for that one reply...
have a nice day everyone.
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 15:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36
Statistics
Newest guides
Latest tool updates
New media comments
