VideoHelp.com Forum
  1. I am capturing video from a vcr using AVI_IO. This works great except for one thing. After a certain amount of time the capture will end due to the I/O Buffer being used up. The buffer up to that point will bounce between 0/50 and 1/50, but at the point of termination, the buffer spikes to 50/50. I think I have pinpointed what is happening. It sounds like a hard drive is spinning up, and at the same time, the I/O Buffer spikes to 50/50, resulting in termination of the capture. This has occurred after as few as 9 minutes and as long as 45 minutes. Any suggestions?
    My hard disk is 40GB 7200 rpm. It is partitioned with 30 GB as a capture drive and 10 GB as system drive. I have DMA turned on, I have screen saver turned off, and I have my power management settings set to always on. I have another hard drive present in my system, a 40 GB 5400rpm drive, but it is not involved in captures. I have 1.6GHz processor, 384 MB RAM. I am capturing video through a Pinnacle Linx USB cable and audio through SBLive. Thanks in advance for any help.
  2. Член BJ_M's Avatar
    it may be partitioned but its still the same drive as your swap file and system files which windows like to take a boo at now and then .. make a seperate capture drive ..
    sometime drives go through thermal re-calibration and can cause those same things ... but i dont really see that anymore happening ...
  1. Japanese VRO Disk problems
    By HDBoxing in forum Software Playing
    Last Post: 19th Dec 2010, 22:13
  2. Anyone familiar with zip spin stand-alone duplicators?
    By AngieM in forum DVD & Blu-ray Recorders
    Last Post: 13th Mar 2010, 10:49
  3. liteon shm-165h6s problems to spin and detect media
    By deejay.2001 in forum DVD & Blu-ray Writers
    Last Post: 29th Aug 2009, 09:28
  4. Replies: 6
    Last Post: 2nd Feb 2009, 03:56
  5. Weird DVDVideo burning issues in Nero (spin up/down/up/down during Lead-In)
    By bobogs in forum Newbie / General discussions
    Last Post: 9th Oct 2007, 22:13
