When i encode with tmpg i use the .d2v file (created with DVD2AVI) and the .wav file (created with headac3he from the .ac3 or using DVD2AVI to convert from the .ac3). In then use VCD Easy to add the chapters and have never had a problem. However, when I encoded the audio and video seperately I have a problem with VCDEasy. I use tmpg to create a .m1v file from the .d2v file and headac3he to create a .mp2 from the .ac3. I then mux them together using bbmpeg with the default settings but change the stream to mpeg1 because i'm using 2 pass VBR at 1700Kb/sec to create a decent quality movie on 2 CD's. When i put in the chapters using VCD Easy, the file size gets bigger. Am i doing something wrong? Should i just go back to my original method?
Results 1 to 1 of 1
Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video StreamingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
dvd help .size.file to large shouldnt be.
By larebow in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2009, 01:08 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48
