VideoHelp.com Forum
  1. when I try to burn it it says that it is not MPEG format, but the movie says it is, I tried re-encoding with TMPGEnc but it will not let me. is there anyway I can re-encode the MPEG to burn it vcd? tried burning with nero 5.5. and tried to re-encode with nero but it will only encode 21 minutes of a 50 min movie.
  2. How won't Tmpgenc let you? details details details....
  3. It says the file already exists. do you want to overwrite? when I click ok, another window pops up saying, the file cannot be created. is there a way I can change the MPEG format to something else and then re-encode it to MPEG and burn it?
    just click cancel and name the file and name the file anyhting else.
    <font size=-1>[ This Message was edited by: dancoe on 2001-08-14 18:52:06 ]</font>
  5. I just tried renaming it like you said and still no luck!
    any other suggestions?
  6. Ok, for the record you are trying to convert an avi to a MPEG1, to burn it as a VCD. Have you read Sefy's Guide to the left on how to do this (either way read them again).
    What template are you loading in TMPGenc? What settings are you using? Does the avi encode? Can you play the MPEG file you generated with media player? etc. etc.
    How are you burning it with nero? Are you choosing the 'burn VCD' from wizard? What about CDI and 'standard complatation(sp)' <sorry about the spelling>
    Lots of things could be wrong, but if you can't play the MPEG file with media player you made a mistake somewhere. Most likely didn't load the a template. But we need more info, sorry...
  7. It works but i tihnk you misunderstood...
    Maybe here's a clearer picture using TMPGEnc...
    Video Source: C:\files\x.mpg
    Audio Source: C:\files\x.mpg
    Output Filename: C:\files\x2.mpg
    Both the file CANNOT have the same filename, TMPGEnc does NOT allow overwrite of filename...
  8. Thanks Dancoe & fatbat your suggestions worked
  1. Burn more than 1 movie on same DVD
    By smithwigglesworth0 in forum Authoring (DVD)
    Last Post: 31st Aug 2011, 22:34
  2. Burn Movie to DVD
    By pfisher in forum Newbie / General discussions
    Last Post: 6th May 2011, 18:40
  3. Help getting a movie ready for DVD burn
    By therock09wbt in forum Video Conversion
    Last Post: 3rd Jan 2011, 19:03
  4. How to burn 7.1 channel DVD movie?
    By coody in forum Audio
    Last Post: 9th Dec 2009, 04:07
  5. Burn AVI movie.
    By mutras in forum Newbie / General discussions
    Last Post: 12th Jul 2007, 20:19
