sup all, i hav some problems recently with burning vcds. i downloaded a few movies from a site, and i burned it as vcd with no problem, but when i play them on my vcd player, some parts seems to go OUTSIDE of the screen.......its like as if my tv is not big enough or sth.....but when i play it on the computer, it works perfectly, nth goes outside of the screen...
may b is it bcuz i didnt choose da correct format....like pal or ntsc????
plz help ><![]()
Thread: Pal or NTSC? plz help ><
NTSC VCD = 352x240@29.976fps
PAL VCD = 352x288@25fps
DVD players should play standard compliant VCDs correctly. If the resolution of your downloaded movies are not standard compliant, there is no garuantee your DVD player will play them correctly. So what can you do about it? 8)
search the boards for:
overscan
the threads you find should explain it in detailAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
hey, thx for telling me dat..
i read the thread...about overscan...and sorry...m a newbie to vcds stuff....i read it and i still dun get it....so can someone plz teach me....plz.........
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Import BluRay, PS3, PAL/NTSC, etc. (Help Plz!)
By Startropic1 in forum Blu-ray RippingReplies: 12Last Post: 22nd Sep 2009, 22:21 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
Statistics
Newest guides
Latest tool updates
New media comments
