DivX / AVI
Read here first http://www.vcdhelp.com/play#divx
I can't play AVI in Media Player?
Be sure to install the latest DivX codec. If that not help install the Gordian Knot Codec Pack or/and the ffdshow that includes most avi codecs. If it still doesn't work use gpost to identify what codecs it uses and then download them.
The movie is up side down?
If the movie plays upsidedown first try remove every DivX codecs including the Nimo Codec Pack and then reinstall only the main DivX codec first and test.
VCD
Read here first http://www.vcdhelp.com/play#vcd
SVCD
Read here first http://www.vcdhelp.com/play#svcd
I can't play SVCD in Media Player?
Install a MPEG2 codec like PowerDVD, WinDVD and you should be able to play SVCD in media player.
DVD
Read here first http://www.vcdhelp.com/play#dvd
How do I play a ripped DVD?
Use latest PowerDVD and select play DVD from hard disc drive and select the folder you ripped the dvd to.
Thread: FAQ -Common playing problems!
You can play the video files off an SVCD using videolan, www.videolan.org - in much the same way that you can play the files off a VCD with Windows Media Player. This doesn't let you use the chapters, menus, etc - but you can see the video and hear the audio.
In both cases, you more or less use the file menu, play a file, navigate to the (S)VCD, look for the MPEGAV folder, make sure you're showing all files - the video files have DAT extensions. The reason you need 2 different players is that they are actually encoded using different standards - VCDs have MPEG1 video, SVCDs have MPEG2 video. There are many free MPEG1 video players, but not many free MPEG2 video players.
One reason I like videolan is that it doesn't mess with your drivers, and of course that it's free. It's available for all OS platforms.
It takes a fair amount of computer power to play DVDs/SVCDs/MPEG2 video, so if you have an older computer, you may see stalls, skips, etc.
If that doesn't work for you, you might want to check your ASPI layer - run the aspichk.exe program at the link below.
ASPI FAQ Link - Bart's ASPI Page
http://www.nu2.nu/aspi/
Question: When I burn a DivX/XviD file onto a DVD and play in my standalone player it looks great filling my entire TV, but when I play it in Media PLayer on my computer and go full screen it looks "blown up". Is there anything I can do? I'm thinking of building an entertainment PC for my living room, but not if the videos will look "blown up" on my TV. Thanks.
I think Baldrick was actually refering to gspot rather then gpost.Be sure to install the latest DivX codec. If that not help install the Gordian Knot Codec Pack or/and the ffdshow that includes most avi codecs. If it still doesn't work use gpost to identify what codecs it uses and then download them.
There are thousands of answers to this question, but here are some basic
troubleshooting steps to help you track down problems such as jerky
playback.
1) Get updated drivers. Driver bugs are the biggest cause of playback
problems, ranging from freezes to bogus error messages about regions.
2) Make sure you have the latest decoder drivers as
well as the latest drivers for your graphics adapter and DVD-ROM
drive.
3) Make sure DMA is turned on. For Windows, go into the System Properties
Device Manager, choose CD-ROM, open the CD/DVD driver properties,
choose the Settings tab, and make sure the DMA box is checked.
Why can't I get any sound out from windows media player when I play ANY dvd but power dvd does?
most common used converters
By alijutt in forum Video ConversionReplies: 0Last Post: 22nd Dec 2011, 20:35 -
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2011, 08:14 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 13:10 -
DV FAQ - Read me first
By Baldrick in forum Camcorders (DV/HDV/AVCHD)Replies: 10Last Post: 11th Jan 2008, 16:40 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 07:57
