VideoHelp.com Forum
  1. Had previous help in fixing a damaged AVI file, was advised about VirtualDub, tried it out and played about with it for many hours today but can't find out how you print out the error log to show at which frames have errors, everytime I "scan video stream for errors" I get an error message at the end of it
    Internal Error MMX state left on: T:\projects\VirtualDub_old\main\VideoSource.cpp:11 01,
    which the offical website says is just a misleading error???
    Have tried going through manually and editing the damaged frames but just when I think its working and its half way through processing, I get another error message, "OutputAVI parameter incorrect" sheeesh!
    Again any help on this would be much appreciated.
    phs
  2. Banned
    Yep I seen your post but was waiting for the other person to reply
    The Vdub you are using has a problem sometimes when scanning... Normally all you need to do is this.
    Video > scan video stream for errors
    Video > direct stream copy
    Audio > direct stream copy
    SAVE AVI
    This saves out another copy without the bad frames !!, you don't need to delete anything !!
    However as I said the "MMX left on" is a known problem, so you need to download another version of Vdub called "vdub-mp3-freeze.exe" from here
    http://www.digital-digest.com/dvd/do...irtualdub.html
    Now this version makes a log of the bad frames at c:\badframes.log
    Video > Check video for freezes
    Now load the log, it may have several blocks, so you need to delete the highest block numbers first (At keyframes)
    12345
    12346
    12347
    3345667
    3345668
    3345669 (Highest block of numbers)
    Open Log and highlight the highest number (3345669) (Control C=COPY)switch to Vdub and select GO TO (Control V=Paste) 3345669
    Now click the yellow keyframe forward once, then mark this as end
    Back to the log highlight lowest number of that block (COPY)(3345667) switch back to Vdub and select GO TO (Paste) 3345667
    Now click the yellow keyframe back once, then mark this as start
    Press the delete key to remove those bad frames 3345667 to 3345669
    Now do the same to the next highest block ( 12345 to 12347)
    SAVE AVI
    Will save out a new copy without the bad frames...
  3. MANY THANKS!
    Finally got the link to work after disabling firewall and D/L the copy you suggested and it finally worked, so thank you for your help.
  4. Banned
    Ah yes the anti leech... pain in the A$$...
    Glad you got it sorted
  1. Editing Question about Virtualdub
    By gatewayedit in forum Editing
    Last Post: 14th Jul 2011, 16:26
  2. New to editing with VirtualDub
    By xNesX in forum Editing
    Last Post: 18th May 2011, 23:56
  3. Editing FLV in VirtualDub
    By CursedLemon in forum Editing
    Last Post: 29th Jul 2010, 23:02
  4. Virtualdub, editing out faces?
    By capman21 in forum Newbie / General discussions
    Last Post: 2nd Mar 2009, 21:12
  5. mp3 editing with VirtualDub
    By tomchook in forum Audio
    Last Post: 2nd Jul 2008, 11:48
