Hi !
What is the easiest way to add permanent subtitles. I´m asking since there are quite a few guides around.
Do I first encode the div x file(TMPGenc) or do I add subtitles directly to the divx file?
I´d be grateful for an answer.
Nille
The easiest way is to add your subtitles in Virtual Dub, while frameserving to TMPGEnc.
Hello.
Originally Posted by Tommyknocker
If I try to frameserve to TMPGenc I get an unsupported file message in TEMPGenc, so I have been saving the results to a compressed avi file (but it takes hours!). How do you get TMPGenc to recognize the .vdf file made by Virtual Dub ?
philip
You must select all files when the Open requester comes up when you select your video input.
Hello.
That enables you to select it but then you get this invalid file format or not supported message...(at least I do).Originally Posted by Tommyknocker
philip
pmcd - have a look at:
http://www.vcdhelp.com/forum/viewtopic.php?t=107096
cheers,
mcdruid.
Disable your DirectDraw filters in the environment settings of TMPGENc (untick) - TMPG should then be able to open the vdr file (at least mine does).
Cheers
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 20:16 -
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeGrow in forum SubtitleReplies: 19Last Post: 22nd May 2011, 05:28 -
How can i add 2 permanent subtitles upside and downside the video?
By farzad67 in forum SubtitleReplies: 18Last Post: 24th Jul 2010, 22:29 -
How do I add or edit permanent subtitles
By VidHunter in forum MacReplies: 19Last Post: 29th Nov 2007, 14:55 -
Add permanent subtitles to an AVI file using a MAC?
By blueblitz in forum MacReplies: 1Last Post: 15th Oct 2007, 05:10
