What's MJPEG and when do I use that? It's a codec from what I understand?
Thread: What is MJPEG?
Thanx/
Lars
I use mjpeg codec when i want to capture from hy Haupauge Wintv PCI card. To reduce captured file size. Then i reencode to whatever format i want.
/ Fredrik
Yes, it's a video codec. It compresses the video as individual images with jpg compression, and not like mpeg where there is compression *between* images as well as single images. Mpeg compression in I-frame mode is basically the same as mjpeg compression. Mjpeg compression is used for high quality video where you can do frame accurate editing.
Sk
Yeah, but what is the differense from MJPEG codec from for example Huffyuof 2.1 codec... is just another codec among all the others or is the MJPEG codec specialized for a certain type of footage or usage?
Thanx/
Lars
The Picview mjpeg compressor has 20 levels of compression, but Huffy has a few levels of compression, all but one level is lossless, so the encoder can only be used for low level compression, like 3:1 The Picvideo mjpeg can easilly do 50:1 compression.
Aha, so could I be using this codec as a capture codec even if I usually capture low quality (VHS) footage? Just to get rid of the file size?
Thanx/
Lars
Convert to MJpeg
By gmellow in forum Video ConversionReplies: 16Last Post: 14th Feb 2012, 04:12 -
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
MJPEG export
By vizion in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2011, 12:52 -
Quicktime MJPEG to XviD?
By udaykhan in forum DVD RippingReplies: 10Last Post: 1st Apr 2009, 10:33 -
MJPEG Testing
By adambklyn in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 01:04
