VideoHelp.com Forum
    Lately my win xp system is acting very stopy(if thats a good description) it s working in stops and starts. every four or five sconds it stalls for like a tenth of a second (only noticible when mobing the mouse) This has got rid of my capturing abilities completely.
    Any help well appreciated.
    Baker
    My vcd & cvdGuide
  2. ok i had a similar problem. i ran norton utilities to fix any window files that were corrupt and i had several and it fixed them all. i then defragged and optimized and it seemed to do the trick
    I have this prob once in a while. I find a simple reset usually fixes it.
    If it doesn't it's a sign my cpu is overheating.
    Thanks for the reply, I have had this problem for a few months now and so reseting it defenetly aint going to work. As for the first guy, I think you may be on to something. Do you know what fixed it exactly?
    Norton utilitties?
    How do i make it scan for bad files?
    Baker
    My vcd & cvdGuide
    I REALLY NEEDSOME HELP. NOTHING I HAVE TRIED HAS WORKED PLEASE GIVE ME A HAND AS I NEED IT. THIS IS REALLY ANNOYING AS I WAS JUST ABOUT TO DO SOME HEAVY DUTY VHS CAPTURING.
    Please help
    Baker
    My vcd & cvdGuide
  6. try reinstalling windows, a fresh start always helps.
    baker,
    This might sound like a stupid question, but have you tried doing a clean install of your OS? You said you've been dealing with this for months, but never mentioned if you did so. Sometimes your better off biting the bullet and reformating.
    I didn't want to re-install as I alweays fuck up when I re-enstall. Looks like I am going to have to do it doh.
    Wish me luck and I will soon tell you the result.
    Baker
    My vcd & cvdGuide
  1. Play back stops and starts but audio is fine
    By muay in forum Video Conversion
    Last Post: 22nd Apr 2011, 12:46
  2. Replies: 2
    Last Post: 6th Jun 2010, 02:12
  3. ffmpeg stops working in VOB2DVD
    By DrDigital in forum SVCD2DVD & VOB2MPG
    Last Post: 9th Nov 2009, 20:14
  4. DVD Shrink stops working
    By guamfrank in forum Newbie / General discussions
    Last Post: 17th Oct 2008, 00:05
  5. itunes stops working
    By angelatony in forum SVCD2DVD & VOB2MPG
    Last Post: 17th Sep 2007, 10:44
