VideoHelp.com Forum
  1. I'd like to now which of the various Authoring software packages support the ability to link to a menu button, both a mpep and audio file. So that when the button is clicked it plays both the Audio and Video at the same time.
    The only package I've seen is DvDit but I've had a lot of problems with PAL/NTSC/Non Compliant mpegs that I'm finding this unusable.
    Anyone with any info on this ?
    Cheers
    Andy
  2. You can check out Impression from Pinnacle. There's 2 versions, a standard one and a Pro.
    If you use Adobe Premiere it's even possible to get Premiere to Export the files,launch Impression, place the files in the timeline for Impression, You can also export chapter marks from Premiere.
    BL
  3. Thanks, I'll take a look at thier web site. Very interested to see if they can use separate Video/Audio files with the Audio remaining in PCM (lossless format)
  1. Replies: 5
    Last Post: 15th Nov 2011, 19:32
  2. Avidemux: How to separate Video from Audio
    By DarkPhoenix77 in forum Mac
    Last Post: 24th May 2010, 02:30
  3. Authoring Software that supports h.264
    By sampalmer21 in forum Authoring (Blu-ray)
    Last Post: 3rd Nov 2009, 09:17
  4. New Video Editing/DVD Authoring Software
    By rodhudson in forum Newbie / General discussions
    Last Post: 17th Oct 2007, 02:47
