Hi I recently bought a Pinnacle Studio PCTV Rave and it came with PCTV Vision software, altho when I try to use VirtualDub to capture using "How to capture to AVI in realtime and after convert to VCD, SVCD, DVD guide from www.vcdhelp.com", the error i get is that it cannot open vid input device?
What can be wrong?
Thanks guys.
I had similar problems with a PCTV card but some people have had good success with the native drivers. You may be able to use an older version of the drivers or use the generic drivers in the other forum:
http://www.vcdhelp.com/forum/viewtop...ht=pctv#304909
I think your card is on the supported list. However, if you do use these drivers, you may lose functionality of all Pinnacle software (including PCVision app). I did.
Also, make sure that you have only one application open that will access the capture device.
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 01:34 -
Cannot open H264 video using VirtualDub
By kinlunyu in forum Video ConversionReplies: 12Last Post: 21st Aug 2011, 14:28 -
Megui cannot open video input
By simonrule in forum Video ConversionReplies: 0Last Post: 6th Dec 2009, 14:54 -
DVD device input not available WARNING!!!!
By crosseyedalien in forum ffmpegX general discussionReplies: 3Last Post: 5th Dec 2007, 16:38 -
Automatically open WinDV when DV device becomes active
By jabloomf1230 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 9th Jun 2007, 22:30
Statistics
Newest guides
Latest tool updates
New media comments
