VideoHelp.com Forum
  1. I have a divx file which has a frame rate of 24.032 fps. There is no template for that frame rate in TPMGenc.
    I've tried both NTSC templates but the sound is off after I encode the file.
    Do I have to use a template or can I go ahead with out one?
    Will it still work on my DVD player if I do?
    What should I try?
    I have A Sony DVP-S550D.
  2. Banned
    VCD specification is 25fps , that's why TMPGEnc has the template.
    However after you load a template, load the unlock template, then you can change it... BUT ! that does not mean it will work at all on your DVD player. It may also upset your authoring program.
    There is only one way to find out, is there not ?
  1. Audio does not match with the video
    By c018279 in forum Blu-ray Ripping
    Last Post: 31st Mar 2009, 04:10
  2. video and audio time dont match?
    By just in forum Newbie / General discussions
    Last Post: 4th Nov 2008, 19:58
  3. Video and Audio does not match
    By hzgg2 in forum Authoring (DVD)
    Last Post: 1st Aug 2008, 19:50
  4. cant get audio to match video
    By loa909 in forum Newbie / General discussions
    Last Post: 31st Mar 2008, 06:35
  5. Conversion of audio to match video
    By deltaromeo in forum Audio
    Last Post: 29th Jan 2008, 12:01
