Every time i try to burn a vcd with Nero...i get the message ....Could not perform fixation burn process failed..... Any idea why Nero won't work for me....worked fine on my old computer![]()
uummm...i dont know what the problem would be but, when i first had problems with nero i used NTI-cd maker plus until i managed to get nero working. i dont know how to fix it so i suggest u get nti-cd maker plus until u get further information on getting it fixed...anyways im just a newb buyt nti-cd maker plus is pretty good for when u have problems...i dont use it anymore tho since nero works...
Ok...i got NTI...but it doesn't recognize my burner. The only option i have is for NTI Image burner.
Sure you arent trying to do a fixation burn to prepare a DVDrw for its first use, but have a cdr in the hole?
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 13:19 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 01:10 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 15:40 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 14:15
Statistics
Newest guides
Latest tool updates
New media comments
