VideoHelp.com Forum
  1. However, the encoded mpg2 by using TMPGEnc reviewed before burning is just fine, with video and audio in sync. I wonder why the burned CD is out of sync while the encoded mpg2 is fine. It is a VBR SVCD burned by Nero 5.5.
  2. Don't get excited I'm not relpying with a soloution.
    I just want you to know that you're not the only one with this problem. I'm experiencing the same thing. I've made a SVCD using CDRWin to burn a .bin file I created with VCDEasy of a mpeg2 I encoded with TMPGenc at CB 1600, which gradually goes out of sync. Why? If I press pause then play on the DVD player it syncs back up again. The original is fine.
  3. See this explanation of the problem--you may try it.
    http://www.vcdhelp.com/forum/viewtopic.php?t=108524
  4. Member adam's Avatar
    Nero also might be causing this problem. I don't have any technical evidence to back this up but i have generally just had difficulty authoring fully compatible SVCDS in Nero.
    I think its at least worth a try to author your SVCD in vcdimager (with gui if needed) and burn using CDRAO. I only suggest this software combination because its totally free. Any other SVCD authoring program and disk image burning program will work.
  1. Replies: 3
    Last Post: 6th Sep 2011, 07:54
  2. Replies: 2
    Last Post: 24th Oct 2009, 14:32
  3. Replies: 4
    Last Post: 7th Jul 2009, 18:13
  4. Audio (or video?)out of sync when burned
    By seragx99 in forum Authoring (DVD)
    Last Post: 28th Jul 2008, 07:05
  5. Replies: 8
    Last Post: 10th Jul 2007, 08:48
