When I get to the stage of CUE/BIN files i burn them using Nero 5.5 but nothing seems to be able to read the cd's when I'm done.Not Win Media Player,Power DVD...nothing....Help please ...it's killing me!!!!
Thanks Folks!![]()
Which version of NERO are you using to burn the Cue/Bin files ? i'd recommand only versions above 5.5.8.0 to do so, if you have anything earlier, i've had bad experiences with it.
You can also use BlindWrite Suite or CDRWin to burn Cue/Bin files.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
The bin files as you know are copies of the disk that was made, if the person has something different to you, then you may have problems. It is just as quick to use an ISO buster and extract the .dat file. Then you can re-make the VCD in the normal way with that .dat file.Originally Posted by Schoonerconsumer
Naturally if there were any menu's etc they would be lost, but there is a better chance of it working if you use the .dat and re-author it again.
ISO busters will open these bin files and show the contents, you can extract everything or just the .dat file
IsoBuster and CD Marge both work well
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
Statistics
Newest guides
Latest tool updates
New media comments
