What is the best to create chapters in cvcd non-standard?
I test easyvcd and works fine, when there is 1 video in the cvcd
but, when I put first a little video (like introduction), and I try to create chapters in the second video , I get a bad vcd, that, no play in dvd & no play in PC
thanks
Thread: Creating chapters
are they both mpeg-1 or mpeg-2...
if so then maybe you need to remux the first video if the 2nd one works fine by itself...Big_Jit
they are mpeg 1 (from divx with tmpgenc)
how remux the little video 1 ?
yes, the second video is works fine, if it is burned alone
open TMPGEnc and click File>Mpeg Tools and then choose the Simple De-Multiplex then give the output name and directory and click on Run.
When that finishes go back to Mpeg Tools and choose Simple Multiplex and for the program type choose MPEG-1 VCD (Non-standard) then click Run
That should do it. You choose MPEG-1 VCD (Non-standard) bcause you said that you were creating a CVCD. Which has a 352 x 480/576 res and other nonstandard but playable properties. Unless you mistyped and meant XVCD where the same would apply...
Hope this helps!...Big_Jit
DVDStyler Not Creating Chapters?
By analytalica in forum Authoring (DVD)Replies: 1Last Post: 31st Mar 2012, 18:10 -
Creating chapters (MKV)
By ignorantbliss in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 10:32 -
Creating Chapters every few minutes
By Subhash in forum Authoring (DVD)Replies: 23Last Post: 6th Mar 2010, 09:44 -
Creating chapters with VIDEO_TS?
By silentsteps in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2008, 22:37 -
Creating chapters using CCE
By hipatuga1 in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 04:10
Statistics
Newest guides
Latest tool updates
New media comments
