I used PowerVCR to capture something to PAL VCD format.
I burned it onto a disc along with another MPEG which is also in VCD format, the second MPEG is deffo 100% fine.
I burned the VCD.
It plays excellent on my PC.
But when I try it on my standalon player, the captured clip stutters constantly and won't play properly, but the second clip is fine?
Why?
Its obvioulsy not the disc as the second MPEG is fine!
Any ideas?
CHEERS!
Gray
Thread: Ok on PC but not on Standalone?
CG,
Check the compatibility of your standalone at this linkhttp://www.vcdhelp.com/dvdplayers.php. Your problem is probably due to your DVD player.
Thanks for the reply!
But if you read the post again you will notice I have 2 clips, one plays fine the other does not.
I have the Lecson 900 which plays anything you throw at it.
Ta!
Gray
let the standalone do the resize (resample)?
By rebl in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 14:46 -
Standalone HD upconverters (upscalers)
By dfyh in forum DVB / HDTVReplies: 7Last Post: 11th Sep 2009, 23:00 -
standalone 16:9 recorder
By dnyboy in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th May 2009, 13:37 -
VobSub and standalone compatibillity.
By therock003 in forum SubtitleReplies: 0Last Post: 16th Mar 2009, 04:37 -
Need Standalone Recommendations
By Thadius856 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th May 2008, 07:52
Statistics
Newest guides
Latest tool updates
New media comments
