Every time I try to load up VCDEasy and enable the CDroa or whatever it is, it just own't find my cd writer. I've put in the aspi drivers and stuff, but I on't know what else I have to do
What OS are you using - WinXP by any chance?
Na, I bet he is using Windows 2000Originally Posted by puCrepeaP
Did you used Adaptec ASPI with the /force command. It comes with a readme file that explains this, and a program to check your system. Then you may need to re-install VCDEasy.
http://www.adaptec.com/worldwide/sup...=aspi_v470.exe
How does HD Writer do it?
By OldNick in forum Authoring (DVD)Replies: 7Last Post: 11th Mar 2012, 19:57 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20 -
Best AVI Writer?
By ouxch in forum DVD & Blu-ray WritersReplies: 13Last Post: 5th Jan 2008, 02:31 -
new dvd writer problems
By carstd01 in forum DVD & Blu-ray WritersReplies: 6Last Post: 25th Nov 2007, 12:58 -
dvd writer problems
By ellabbs in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 16:05
Statistics
Newest guides
Latest tool updates
New media comments
