Once you rip a DVD, what is the best format to encode it to just for keeping it on your computer. I encoded one big file with TMPGEnc SVCD with the highest bitrate(2520 is it?) and it turned out pretty good, but the file is 1.6 gigHow does MPEG compare to Divx, quality wise? I know Divx files are a lot smaller, and the ones i have on my computer are pretty good quality. But are Divx and AVI the same thing? Because i've downloaded stuff that was "divx", but the file is actually an AVI.
thanks for any help
Divx is a type of compressed avi file. So yes a divx will have an avi extension. In general divx can be compressed down to smaller sizes than mpeg (vcd or svcd), but retain comparable quality. Or they could be of a comparable size with superior quality, depending on the source of course.
So for just storing movies on a PC divx would be a more efficient use of space than vcd or svcd.
Craig
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 22:10 -
re-encoding vid file for smaller size but keeping same format?
By WidowMaker in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 13:56 -
Difficulty In Converting .Vob to Any Format & Keeping Widescreen
By RachelArcher in forum DVD RippingReplies: 50Last Post: 10th May 2008, 10:40 -
re-encode while keeping the exact number of frames
By bt04 in forum Video ConversionReplies: 16Last Post: 25th Feb 2008, 19:21 -
Cannot encode VOB file to any format - all binaries installed
By designillinois in forum ffmpegX bugs and suggestionsReplies: 4Last Post: 26th Aug 2007, 13:05
Statistics
Newest guides
Latest tool updates
New media comments
