I heard somewhere that I needed to do that with this Pioneer DVD-R burner.
Please tell my why, if that is true, please?
And how do I make the DMA setting stay? I go into Device Manager(In my Win98 computer), I check the DMA box but when I look in there later, the box is Unchecked again. Why is that?
How can I make the setting stay?
When u enable the DMA setting, it tells Win98 to restart with DMA enabled but if it detects that the DVD drive is not DMA capable it turns it off.
I had this problem with my DVD rom. It was on the secondary ide channel as a slave, with my CDWriter being the master. The CDWriter is UDMA2 but the DVD was reported as PIO which is *REALLY* slow.
My solution to u is to put u're DVD-R burner to master on the secondary ide channel.
If its already on master then u've got me stumped!
DMA stands for Direct Memory Access .
If your device is DMA enabled , all acess with memory neednīt a step via
CPU , meaning less time to move your bits from/to device from/to memory
NO DMA : Device -> CPU -> Memory
WIth DMA : Device - > Memory
One step less , more speed in data transfer....
Hi Rock Jr,
Are you saying you can enable DMA only on the master, but not the slave?
I'm set up like you....CD-RW as master, DVD-R as slave.
If I do that, then are you saying my CD drive will not get DMA enabled? I use that more than my DVD drive. Can we not do it for both somehow?
Alb1no,
Yes, I'd heard that. And it always seemed like a good idea.
But had also heard that "some problems" could arise and wondered what folk here thought about the benefits as opposed to hassles it has caused them personally.
Hey JoeAgain,
I've never had any problems with me DVD as Master and me CDRW as a slave.
B4 I changed me DVD to Master, me CDRW was reported as Ultra DMA mode 2 but me DVD rom was reported as PIO mode. I figured it was a bit fishy so I switched 'em
Now, me CDRW is still reported as Ultra DMA mode 2 *AND* me DVD rom is reported as Ultra DMA mode 4.
As for the speed gain, well its definitely a *BIG* improvement. From a measly 2-3x read speed, its now reading between 11-14x!!
I'll let u decide JoeAgain whether u want the improvement or not. If it gives u hassle, put your CDRW as slave on the primary ide channel and leave your DVD-R as master only on your sec ide channel.
Pioneer DVR-118L internal IDE Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 1Last Post: 26th Sep 2009, 17:07 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
Pioneer DVR-543HS , is my DVD burner toast?
By stew182 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2008, 12:57 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 14:25 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20
