All,
I'm trying to convert an mp2 file with high vbr to lower vbr, but I'm not sure how to go about it. I have CCE 2.5, but it doesn't recognize mp2 files as importable extension. Is there a product that I could use to convert to an AVI file, or a different program I could use to do the conversion? I'm trying to get my captured 8mb VBR down to 2.3mb VBR, so I can fit more per CD & make it SVCD compliant.
Thanks!
-ANthony
Thread: mp2 to mp2/avi conversion
you could frameserver with dvd2avi or avisynth directly to cce
http://forum.vcdhelp.com/userguides/87270.php
If your 30 days has not expired on TMPGEnc, or you have the authorized TMPGEnc Plus, you can load it in one of them, select Load, your favorite template, select Settings, then your VBR. Select Start and you are good to go.
Hello.
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
Extract audio from MP2 and more
By txl in forum AudioReplies: 7Last Post: 30th Jul 2009, 06:49 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 05:32 -
Vodai MP2 codec
By ljs3 in forum ffmpegX general discussionReplies: 1Last Post: 9th Jun 2007, 02:38
Statistics
Newest guides
Latest tool updates
New media comments
