One option greys out the boxes to enable CCS keys, but the other allows me to choose between no CCS and CCS enabled.
Is this like DVD+RW's compatibility mode?
One is like 2,058 bits or kilobits and one is like 2,054, the latter allowes me to input a ccs key.
Would I get slightly better compatiblity by using the 2,054 without a CCS key?
Do you mean CSS? The information I've read indicates that DVD-R/+R technology does not allow the sectors of a disc to be written where CSS encryption keys are stored, so if you turn that option on it will either prevent you from burning or be irrelevant unless you press your DVD.
I know it can't record the actual CSS key, I dont have a valid key.
But would i get higher compatibility if the sector was formated to 2,054 bytes.
I don't think it will affect compatibility. In fact, if you don't have a valid key and simply put a random one in (if it even allows that), you may find yourself with an unplayable disc if it can't be decoded by the hardware.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Removing Subs to reduce MKV size / other options?
By kmcc in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 16:55 -
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 14:23 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 07:17
Statistics
Newest guides
Latest tool updates
New media comments
