I can't copy a dat file from cd to my hard drive. Getting a message "Cannot copy ooo file. Invalid MS-Dos Function." What can be the problem? Any solutions !!! Please help.
Thread: can't copy dat file
Hey Art,
I had the same problem with DAT files not being able to be copied to my hard drive.
I am not positive.... but I think I had to change the extension of a file from scsi1hlp.hp to "scsi1hlp.vxd". I have an HP computer, so they probably renamed the extension to "HP" to disable it. If you do a "find"
on your PC for just the name (not extension), then change it to "vxd", that should do it, (you may need to reboot).
I just checked my machine, and my file is in the \windows\system\iosubsys
folder....
If it doesn't work.... change it back to what it was....
Guesthave u tried clean it up your cd? maybe its dirty or something. I always do that when i cannot copy my dat files
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 10:43 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
Statistics
Newest guides
Latest tool updates
New media comments
