I just had a few questions about the new DMR-HS2 coming in October. I know it has a 40GB hard drive to store shows and stuff on, but are we going to be able to edit what is on the hard drive before we burn it (take out commercials, unwanted parts, etc.)?? One more thing, are we going to be able to put a larger hard drive in instead of the 40GB? Thanks for any info. I checked out the articles you gave us Kus, but couldnt find the answers to my questions.
Drew
Thread: Panasonic DMR-HS2
--Drew
As long as we're asking questions, I've got a few.
Do you know if we'll be able to edit our chapter points, and if we'll be able to create menus with pictures?
Are these already released in Japan? Has anyone actually used one?
Do we really have to wait until October? I'm ready to buy one now!
-Mcpix
Well be prepared it will have the Serial Mangment Copy protection chip built in it so no digital copy can be done say from DVD or any they put in your Dishnet or cable signal including Macrovison. Hollywood is flagging all HDTV channels with a signal that will prevent copies of any program they see fit, they want to control the programs you can and can not record, just read the article in Sept. 02 of Sound & Vision. I have their DMR-E20 recorder and there is no way to defeat the Chip, I was lucky and found a DVD Player that you can upgrade the Bios to defeat the serial Mangment System, but if dishnet decided to include the SMCS in a program I would not be able to record it. Yes digital recording is coming and will be limiting the way we can record.
I'd be willing to wait for the DMR HS if I thought the price is going to be in the same price range as the DMR E20 or E30. Do you know what its approx price range will be?
There was an article that I checked out on it. The MSRP is going to be $1199.99. I dont know a lot of places that go by MSRP so much, so we might see it for $999.99 or something around there.
As for copy protection, there has to be a way to kill it. There is a way around everything else, and I am sure they will find a way around this. Im not concerned with DVD2DVD copying anyway, thats why I have the A04. I just want something that I can record TV shows onto.
But like I said, someone will find away. I cant wait until October!
--Drew--Drew
Yep. MSRP $1199, and thus I'd expect somewhere between $800 and $1000 street.Originally Posted by Drewlo
Yes, you can defeat the copy protection (and I'm not just talking about Macrovision) but the things that do that aren't cheap or easy to find. For most TV shows this is not going to be a problem though.
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
