i found a bunch of propaganda movies on the internet
http://archive.org/movies if your interested...anyway they have them in divx, mpg1 (vcd) and mpg2 formats...obviously the mpg2s will have a higher resolution and so if its possible i want to burn them to a cdr (i dont have a dvdr drive) so i can view them on a dvd player with the highest possible resolution and quality (eg svcd) i'm running OSX 10.1.5 on a 500mhz G3 w/ 256mb ram... any ideas?
thanks
you can author mpeg-2 files to SVCD with VCDToolsX
ok i have that program but how exactly do i do it? theres no good documentation that i've found and i'm very new at this...thanks for your help
use the vcdXgen option to create an XML file from the .MPG, then use the toastXAimager option with that XML file to output two .img files you can burn with Toast XA multitrack mode (trash the _pregap and the .toc files).
I have a cheap $90 Mintek DVD player that plays VCDs. I have found it will play relatively high bitrate MPEG-2 files right off of a CDR saved just as files not in VCD or SVCD file format. You might want to give it a try. It can't hurt.
Russ
DVD player does not read DVDs anymore, CDs - OK?
By unixoidal in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Sep 2010, 02:34 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Can't play or view atleast any of my movies
By metsven in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2008, 07:35 -
Desay dvd player to view on my computer ...how?
By Boothbay in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 11:58 -
best app for burn a video clip to view on a DVD player?
By yolao in forum VCDEasy GeneralReplies: 0Last Post: 8th Jul 2007, 13:34
