Hi, i use tmpgenc, but i cannot figure out how to go from widescreen to full screen. I have tried cropping, and resizing but i lose quality on picture. Is that because i am encoding afterwards? I would like to know how to do this without STRETCHING the video and ruining the quality.
Thanks for your time,
Thread: From widescreen to full
In TMPGEnc, go to the advance properties section. This can be done by clicking on the "settings" button at the bottom if your not using a template, or if you are using a template, you can select the following settings by clicking on the "expert" button after you select the source range.
Once in the advance section, change "source aspect ratio" to 4:3 625 line (pal) or 4:3 525 line (ntsc). Now select "video arrange method" and select "no margin (keep aspect ratio).
You can also select "custom size". Then in the 2 small boxes enter 448x288 for pal, or 448x240 for ntsc. This will keep the movie to the correct aspect ratio but at full screen.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 33Last Post: 8th May 2012, 22:45 -
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Capped MJPEG (or DV) => H.264 widescreen full res
By raffie in forum Video ConversionReplies: 13Last Post: 14th Sep 2009, 07:37 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20 -
What makes widescreen different from full?
By Deathwish in forum EditingReplies: 31Last Post: 7th Jul 2007, 19:28
Statistics
Newest guides
Latest tool updates
New media comments
