VideoHelp.com Forum
Poll: If you owned an ADS Instant DVD, did you decide to return or sell the unit due to various problems?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 14 of 14
  1. To any one considering buying an ADS Instant DVD, you might want to check out the PC Magazine review of this product first.
    http://www.pcmag.com/article2/0,4149,425685,00.asp
  2. Member Craig Tucker's Avatar
    I personally would'nt buy any usb 1.0 capture device, I don't think usb1.0 has the necessary bandwidth (12mb/s max).
    Craig
    craig, if you were talkinga bout xfer of avi over usb you would be right on.. but 5 MBPS xfer of mpeg 2 is NO PROBLEM. Owning this unit and being unhappy with it, i can tell you that it has nothing to do with xfer speed through the usb bus, it has everything to do with the output not working, the vcd direct capture looking like crap, the tech support being aweful, the software to edit causing a loss of sync in mpeg 2 files, it takes me just as much time if not more now and i get as good or better results with avi cap from my $40 wintv card..for vcd obviously, maybe when i get a dvd burner i will have a different opinion. the dvd cap qual is nice...just not the right piece to make vcd's IMHO.
  4. Member Craig Tucker's Avatar
    I was talking about AVI, as I capture using huffy and then convert, as I find I get the best results doing it this way. Transfer rate is generally 13mb/sec and up.
    Craig
    ahh, i see. well in that case this one is definately out as it won't capture avi at all.
  6. For compressed mpeg capturing, USB is fast enough, but not for AVI. Hauppauge sells a USB AVI capture device, but they must compress the AVI a great deal to make it work with USB, so quality would not be that good.
  7. While ADS Instant DVD users are STILL waiting for new software updates that will *fix everything*, Hauppauge has just released a new beta driver for the WinTV PVR USB. ADS could learn a thing or two from Hauppauge!
  8. Member SHS's Avatar
    Barnabas if I call rigth I think ADS Instant DVD also is using the same chip as Hauppauge know as iCompression iTVC12.
  9. No, you recall wrong. Hauppauge uses an IVAC chip, while ADS uses a Stream Machine chip.
  10. Member SHS's Avatar
    IVAC= iCompression iTVC12
    Oh ok to ADS uses a Stream Machine chip
    If you do decide to buy it make sure you have a full duplex sound card. I bought a brand new Sony computer, and it didn't have a full duplex sound card. If you don't know if you do call tech support and ask them.
  12. As the Hauppauge PVR's capture and compress the audio along with the video with the device itself, I don't think you would have to have a full duplex sound card, but you sure would need one with the ADS Instant DVD which must use your sound card to capture the audio.
    for external av capture, nothing beats firewire.
    yet, i havent' seen anything from the usb 2.0 camp.
  14. Hello,
    where can I get another Capture Card with USB 2.0 -Connection?
    I've found 1 in your Card list:
    Provideo PV-356T PRO (Interface:USB 1.1 / 2.0)
    Can you tell me the price?
    Thank you.
    Regards,
    W.H.
  1. ADS Tech Instant DVD
    By bolintx in forum Mac
    Last Post: 3rd Aug 2008, 02:32
  2. Replies: 3
    Last Post: 25th May 2008, 19:52
  3. ADS Technologies Instant DVD 2.0 Driver Download
    By alexsum in forum Newbie / General discussions
    Last Post: 17th May 2008, 20:58
  4. Panasonic DMR-ES10 Reviewed
    By zorankarapancev in forum DVD & Blu-ray Recorders
    Last Post: 1st Apr 2008, 21:45
  5. Replies: 1
    Last Post: 11th Dec 2007, 15:24
