Hi all, I'm trying to patch my new Centrum Gemini DVD-player, but keep running into problems. Info I get when pressing Menu+7+4+2+0:
Player Version: STCinemaster - Build 1.312
Driver Version: 3.0, Build 493
Region Code: All
Drive Type: ATAPI - Type 0
Memory Config: 8192 KB SMI, 0 KB EMI
Audio Dac: CS4335-3
I've downloaded the files from www.veseg.com, changed just a few setting with abconfig, from the original settings. Burned the files onto a CDR ISO-9660 Type 1. The player recognizes the CD as Boot Disc and boots. It gets to loading HWS.AB when it says:
Error - Can't read config file
Pauses and shows the following message:
Failure at Step 12: Error 0x80004017
The target system ghas NOT been updated
Please turn unit off and then on again.
Does anyone know what's going on????
Thanks in advance.
Nik
Results 1 to 1 of 1
Patching a MOV-file from 50 to 25 FPS without frameloss & re-encode?
By Oneirophile in forum EditingReplies: 1Last Post: 11th Oct 2011, 06:29 -
Not Patching DTS
By Torontor in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 18:57 -
Installation of a large CM Gemini II CPU HS in a HTPC
By redwudz in forum ComputerReplies: 5Last Post: 3rd Oct 2008, 18:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 09:17
