I am having problems burning DVD with the latest Nero set to DVD VIDEO.
It gives "file reallocation "errors or file not even number size etc.SO....
I use the DVD UDF/ISO (create VIDEI?AUDIO_TS etc ) and it works....
AM I doing wrong.Will the disc be less campatable/reliable when I use DVD UDF/ISO instead od DVD VIDEO?????
ROB
Originally Posted by robreed
What exactly are you doing,trying to copy a DVD or create your own from Mpegs you have? Also are you useing a ripping program?
I am trying to back up DVDs(rip with DVD decrypter and burn with Pioneer A04 using the latest version of Nero.Latest Disc reallocation error :file not a multiple of 2.(When usin DVD Video setting in Nero)
i think i recall seeing at when some files got messed and nero though they were 853 x 480 .. files proccessed through mpegedit pro do this some times also ..
you can try to demux and remux or re-encode
All you need to copy a DVD is the latest version of nero and smartripper.
Download smartripper and launch It.Once It reads the DVD and goes to the next screen,select backup,which shows all the files contained on the DVD.Once you select the target at the bottom to specify where you'll save too,the start tab will show up afterwards.Press start to begin ripping.It should copy the DVD into a file in whereever you wanted It saved.
Then once copied,start nero up,select DVD-video.Then click new and locate the file where the DVD was copied.Open It up and highlight everything in the folder,then drag It all to the red Video_TS folder.Leave the audio one alone.Then all you do is open the write dialog box up and click write.It should make a backup of the DVD,unless It's one that's bigger than 4.7GB.
I am using the latest version of NERO.
The problems only come when the film is over 4.7gig and I have to use IFO editor to either split discs or remove Audio bits.
I have only had a problem with the latest verion of NERO 5.5.9
"DVDvideo files reallocation started
File size is not of a logical block size (2 kb)
DVD video files reallocation failed"
IS THERE A PROBLEM USING DVD UDF/ISO for Dvd video nurning??????????????????????????????????????????? ??????????????????????????? (which is the only way I can get it to burn)
if you can only use DVD UDF / ISO due to you editing vob files with ifo edit, then it should work. I used to burn my vob files using the DVD UDF/ ISO selection until 558x builds came out with the option of DVD Video. The older UDF / ISO burns work fine on my 3 dvd players.
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 21:51 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
