I have two cards I could use to capture. They are in different computers. One is a DC-10+ and the other is a PCTV card. Using Virtualdub with the DC10 card I seem to only have the mjpeg 24 bit choice. Other choices for data format give me an error when they are choosen. Capturing with the mjpeg 24bit data format only works in Studio 7 to convert to mpeg2 and Studio 7 doesn't say if it's constant bit rate or variable. The LSX encoder won't use the AVI file.
1. Is there a way to use a different data format with the DC10+ card?
2. What AVI data format should I use so I can encode with other mpeg2 encoders?
Some of the capture codec's are specific for capture cards and may not work with other cards.
Install the Nimo codec pack, this may give you more to select.
Video Format and Conversion Questions
By djtech2k7 in forum Newbie / General discussionsReplies: 20Last Post: 9th Jan 2012, 20:26 -
Multiple questions on best file format & quality, conversion from AVCHD
By Scanderoon in forum Newbie / General discussionsReplies: 12Last Post: 2nd Sep 2011, 01:37 -
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 20:24 -
MPEG2 conversion related questions
By nb23 in forum Newbie / General discussionsReplies: 20Last Post: 23rd Sep 2009, 00:22 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 10:39
Statistics
Newest guides
Latest tool updates
New media comments
