VideoHelp.com Forum
  1. I have frame droppign when capturing, and not sure if DMA is ON or OFF. How can I tell, and change? This is my HDD:
    Seagate Barracuda IV 80GB 7200RPM UATA/100 9.5ms 25dB
    Is that fast enough?
  2. Member xzarkad's Avatar
    Your harddrive is more than fast enough.
    Framedrops can have multiple problems, like:
    Your CPU is not fast enough
    You do not have enough RAM
    You mainboard is not fast enough
    You have programs running in the background
    DMA is not enabled
    Which OS do you use? Which CPU do you have? Howmuch RAM? Any programs running?(Like antivirus, screensaver etc etc)
    The Dutchman
  3. Member xzarkad's Avatar
    Apologies, I did forget to answer your question.
    As I have a dutch OS, I will translate and hope that I have the correct names for it...........
    Go to start, settings and system. Select your hardrive and check DMA.
    Under System, you can deselect "write behind cache" This might help for capturing.
    The Dutchman
  4. Thanks, I switced to DMA, and nothing improved, and I then Ir ead that I should update my VIA drivers, and it worked. Thanks for the DMA help.
  1. Enable VCD LG BD370
    By mairel in forum DVD & Blu-ray Players
    Last Post: 4th Nov 2009, 14:17
  2. Enable AVIS in ffdshow?
    By seven_deuce offsuit in forum Newbie / General discussions
    Last Post: 24th Sep 2009, 19:12
  3. Can you enable DMA for an external DVD burner?
    By Erasmus in forum DVD & Blu-ray Writers
    Last Post: 6th Sep 2009, 10:10
  4. enable desktop composition
    By pazer in forum Capturing
    Last Post: 26th Jan 2009, 13:02
  5. How To Enable PC To Read DVD-R
    By Jjay in forum Authoring (DVD)
    Last Post: 5th Jan 2009, 16:47
