i dont know what's the problem is but after using vcdeasy to make the bin file and burn it out. My movies doesnt have smooth sound when playing in my Pioneer DVD player. I put the same disk into my computer and the sound work just fine. I checked the encoded mpeg file, the sound work just fine. So that's why i suspecting that it's might have something to do with vcdeasy when it making the bin file. It worked before when but after i format my computer it started to have problems. Can anyone helps? oh yeah i am trying to make Svcd (mpeg-2) thanks
Results 1 to 1 of 1
Thread: VCDeasy Help
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
