I am thinking of buying the Mediostrean NeoDVD that converts DV through firewire to DVD format directly. This program does not give mpeg2 files as an output, instead it writes DVD images. The other program from the same company (CamPeg RT) does mpeg2 output only and cost $250 vs $99 for NeoDVD.
The reason for wanting the mpeg2 back is for possible re-authoring the DVD at a later time.
My question is: is it possible to extract the mpeg2 files from DVD images losslessly ?. I have read the tutorial in vcdhelp.com that involves using DVD2AVI then Tempgenc.
I assume that this is a lossy process even if the output template is set to DVD mpeg2 type.
Can mpeg2 be recovered by merely stripping header infos from the DVD image ?.
Thanks in advance.
DVD format (VOB files) are just specially multiplexed collections of mpeg video and audio along with timing and navigation information.
The mpeg video can be demultiplexed (demuxed) from the VOB file stream without any loss of quality. It will lose quality if only you re-encode the video (to a different format/resolution/bitrate/etc).
You sure the marketing lingo isn't misleading ? A lot of packages nowadays can encode mpeg2 video in realtime, but the formatting for DVD is usually an additional processing step.
It is strange that Mediostream sells NEODVD that does more for less than CAmpeg Rt, which is th engine that powers the NeoDVD.
I have read the manual of NeoDVD online - mpeg2 output is not an option. You have to buy Campeg RT if you want mpeg2 files.
Check it out at
http://www.mediostream.com
Is there a single program that extract mpegs besides the DVD2AVI &Tempgenc ?.
Thanks.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 7Last Post: 26th Dec 2011, 17:38 -
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 05:55 -
How do I losslessly join 2 DV-AVI files?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2010, 11:07 -
Extract/Create Mini DV Metadata and etc...?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 139Last Post: 23rd Nov 2009, 07:01 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 20:34
Statistics
Newest guides
Latest tool updates
New media comments
