VideoHelp.com Forum
  1. Okey , first of all its something with the audio on the .avi file.
    it will not run in vdub but after i installed nimo package the audio runs under window media player.
    i took the .srt file and converted it to .ssa and used the filter in vdub to get it in. after that i should start a frame server. i did so..
    here is where the problem began. tempgen wouldnt open the file.vdr.avi file that i created. i tryed switching the VFAPI plugin priority but it didnt help.
    so please what to do.? , i badly want the subtitle to work , becuse its a japanese movie
  2. Member xzarkad's Avatar
    I had the same problem. If TMPGEnc will not open the *VDR file, then open TMPGEnc two or three times simultaniously. at the second or third time, the *vdr file will be accepted. Then use ALT-CONTR-DEL and close the frozen TMPGEnc programs.
    I hope this helps.
    The Dutchman
  1. Subtitle problems using convertxtodvd
    By gtorres001 in forum Authoring (DVD)
    Last Post: 3rd Mar 2012, 01:36
  2. Subtitle problems
    By Mrs Cee in forum Newbie / General discussions
    Last Post: 8th Sep 2010, 18:09
  3. Subtitle problems
    By neroman00 in forum Subtitle
    Last Post: 30th Dec 2009, 03:15
  4. Subtitle displays problems
    By dudeman316 in forum Subtitle
    Last Post: 6th Nov 2009, 10:17
  5. Subtitle problems
    By artistguy68 in forum ffmpegX general discussion
    Last Post: 27th Jan 2008, 19:40
