I was wondering if there is a way to figure out the bitrate and quality of a satellite stream capture or VHS capture. Does virtualdub tell you the kbps of a satellite stream, if you connect the satellite to the Video In port? Will any other program do this?
Bitrate is a term associated with digital video not analog.
When you capture video from your satellite system or VCR, you are capturing an analog signal. You determine the captured bitrate of the video through your capture settings.
Are you sure the satellite stream is an analog signal? I have DSS and I thought it was a MPEG2 digital signal.
The satellite stream is probably MPEG2 but it is converted into analog by your set top box.
There are some interesting developments at www.no-access.de where a Nokia STB can be modified to directly interface the MPEG2 stream to a PC.
How to determine best quality when purchasing blank DVDs
By yznf in forum Newbie / General discussionsReplies: 14Last Post: 10th Feb 2012, 15:15 -
How: Converting incoming video file into live stream?
By 2Blive in forum Video StreamingReplies: 0Last Post: 14th Nov 2009, 13:00 -
Saving incoming video stream using VLC 1.0.1
By CKQueen in forum Video StreamingReplies: 2Last Post: 10th Aug 2009, 06:51 -
How to seek a sound stream or determine where you are in a sound stream
By CogoSWSDS in forum ProgrammingReplies: 0Last Post: 19th Jan 2009, 22:05 -
How do you determine if your transport stream is faulty?
By yoda313 in forum DVB / HDTVReplies: 20Last Post: 21st Jul 2008, 02:10
Statistics
Newest guides
Latest tool updates
New media comments
