VideoHelp.com Forum
Results 1 to 9 of 9
    When I capture Simpsons episodes(which are broadcast in Dolby Surround) and then convert to CVD and burn 'em with Nero, I get no surround sound when hooked up my surround sound reciever. Does converting the audio to PCM 44.1/16 and then to mp2(192 kb/s, 44.1 khz, 16 bit) destroy the surround effects? I thought the surround sound was matrixed in to the stereo signal. I know my reciever is working fine, because I get DD 5.1 in the Simpsons Season 1 DVD set and Pro-Logic sound on the 2 channel track of the same set. Can anyone offer some insight?
  2. Renegade gll99's Avatar
    You don't say how you encode but if you use tmpgenc use dual channel mode not stereo if you want to preserve the Dolby.
    thanks for the advice, i have been encoding in stereo mode. I will try dual channel and see if this helps. Thanks again
  4. I am not sure how you are capturing but wouldn't your sound card have to have a "spdif in" in order to maintain the dolby digital surround sound?
    I always use stereo and always ge dolby.
  6. The Old One SatStorm's Avatar
    The only mode which "destroy" the suround info, is the joint stereo mode
    I use Stereo and only stereo in my encodings and when the source is suround, it stays that way....
    Dual Stereo for some users is better for lower bitrates. For 192kb/s, Stereo is the most common option (most of DVB broadcasts are 192kb/sec Stereo)
    Dolby prologic and prologic 2 are for the audio decoding, the encoding is another subject!
  7. Am I missing something? How can you have a dolby digital file if you have an analog capture card? Unless you are capturing audio through a spdif-in (i.e. digital in) (available on some Soundblaster soundcard) or unless you are capturing through firewire, I can't see how you could maintain a dolby digital signal upon capturing.
    Dolby digital and dolby surround are not the same animal.
    http://home.earthlink.net/~kantack/surround3.htm
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  9. Thanks for the clarification. It's easy to get confused with these terms.
  1. Replies: 26
    Last Post: 6th Nov 2010, 17:38
  2. Replies: 4
    Last Post: 28th Jan 2010, 08:10
  3. ac-3 pro plugin and dolby surround
    By ecc in forum Audio
    Last Post: 24th Dec 2009, 11:14
  4. Converting WAV file to Dolby Digital® 5.1 Surround
    By roma_turok in forum User guides
    Last Post: 16th Nov 2008, 22:32
  5. Dolby Digital Surround EX encoder
    By grasswhopper in forum Audio
    Last Post: 17th Aug 2007, 23:49
