VideoHelp.com Forum
Results 1 to 13 of 13
  1. what is the best capturing software ???and what is the best settings for it .
    i going to make vcds out of my home videos on my annlog handy cam.
    i have used powervcr2 and virtualdubing which had better quality avi file but i am still not happy my setting with virtualdubbing
    video compression i used mircosoftmpeg 4 video codec v1 and put the sharpness to max and data rate to max and audio to pcm 44.100khz 16 bits stereo 172 kb\sec .and format to 352x 288 rgb555 16 bit(and used nero to encode) virtualdubbing wouldnt let me put the resolution up for some reason because i was going to use tmpgenc to resize it can some one help thanks
    have a good one
    Try the following:
    Virtualdub
    Huffy AVI Codec (make sure you have lots of drive space, 2:1 to 3:1 compression, but lossless)
    ADPCM Codec audio (should be included in Windows, 4:1 compression)
    Then
    Encode with either TMPGEnc (look for early version) or CCE (free to test, but not to keep)...
    You will NOT regret it.
    I use this setup, 480x480 captures, virtually no loss of frames (except for V-Dub correcting the sound card issue) and it's like encoding from DVD source video.
    I wouldn't capture to MPEG, MPEG-2 unless you absolutely must, I also wouldn't use NERO to do anything but make audio or data CD's.
    BTW: what hardware are you using? This might effect the max capture size...
    and, did you try "custom capture format" in V-Dub? This is the only way I can specify my 480x480...
    Try capturing 480x576 YUV2. If virtual dub doesn't let you choose XXX x 576 resolutions, try switching to preview mode (Many capture cards can't deal with the both fields when in overlay mode). Picvideo MJPEG at quality setting 19 should give as good results as Huffuv but with a lot better compression (if you don't have hundreds of gigabytes to spend).
    CCE gives the best encoding quality, but TMPGEnc will do too. Never use Nero for SVCD / VCD encoding. You're capturing from analog cam, so I would try to encode as 352x576 interlaced XSVCD with video bitrate around 1800. This gives alot better quality than standard VCD. Try if your player supports this format (if it plays SVCD it'll play this too)
  5. The Old One SatStorm's Avatar
    TMPGenc acts strange with Mjpeg avis....
    Old (ver 12, 12a) worked better with pic video for example IMO
    With Huggyuv, you have better results if you use the newer tmpgenc plus versions
    With CCE, both codex work great!
  6. firstly thanks for everybodys help
    and i was wondering where can download Huffy AVI Codec ??
    thanks again
    have a good one
  7. The Old One SatStorm's Avatar
    Visit the links and the tools section of vcdhelp
  8. could you email yur Special DLL please and where did you down load version 5??
    thanks again alpal
    have a good one
    Can I get that dll too?
  10. CONTACT ME by MSN only
    i can't send FILES trought Hotmail.com, sorry.
    I don't use MSN...
    Do you have ICQ?
  1. Capturing software
    By sruddy in forum Capturing
    Last Post: 7th Feb 2011, 13:53
  2. capturing software
    By fabpozzi in forum Capturing
    Last Post: 23rd Oct 2009, 07:04
  3. Replies: 22
    Last Post: 28th Feb 2008, 15:38
  4. best video capturing software?
    By majax79 in forum Newbie / General discussions
    Last Post: 3rd Jan 2008, 15:40
  5. screen capturing software issue
    By snafubaby in forum Newbie / General discussions
    Last Post: 29th Oct 2007, 03:37
