Hi all
I am trying to burn a file less than 80 minutes on a 700 Mb CD but I often get an error that says:
17:56:30 #15 SCSI -1013 File Cdrdrv.cpp, Line 1308
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03DBF898
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x09
CDB Data: 0x2A 0x00 0x00 0x00 0x24 0x93 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x09
17:56:30 #16 mmc -1013 File Writer.cpp, Line 308
Buffer underrun
17:56:30 #17 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
17:56:34 #18 Text 0 File ThreadedTransfer.cpp, Line 212
conversion idle, stopping reader
17:59:37 #19 mmc -1065 File WriterStatus.cpp, Line 135
Invalid command
17:59:37 #20 TRANSFER -24 File WriterStatus.cpp, Line 135
Could not perform end of Disc At Once
17:59:38 #21 Phase 38 File dlgbrnst.cpp, Line 1348
Burn process failed at 2x (300 KB/s)
17:59:38 #22 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Can someone tell me what´s wrong ?
What should I do to fix this ?
Thread: Nero - Burn process failed
Regards,
Duddi
"17:56:30 #16 mmc -1013 File Writer.cpp, Line 308
Buffer underrun"
If your drive supports Burn-Proof (or similar BU protection), check the box in Nero to enable it. Buffer Underruns = coasters. If your drive does not support any BU scheme, get one that does.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Thanks Mirror_Image
Can you tell me where to find this check box ?
I have looked but I haven´t found it yet.Regards,
Duddi
Let's go at it this way:
What is the brand and model number of your CD Burner?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Lower your burn speed until you no longer underrun your buffer.
I also have a Burning problem with nero ..... When I try to burn something, it starts the process gets a little way in then comes up with a "DMA target error" (or something like that..) and says burn failed. That disc is then unusable ..... If I then put in another disc (same brand/type) and hit the burn button again (having changed NONE of the settings) It will complete the task with no problems !!! (and this happens EVERY single time) Any ideas ??
I did wonder if there is a "recomended" connection setup, currently.
Primary Master = HDD (UDMA mode 5(ATA100)) Slave = none
Secondry Master= DVD-ROM(ATA33) Slave = Lite-OnCDR/RW (ATA33)
FYI :
AMD XP1600 cpu, Win 98, 512MB ddr ram. Nero ver 5.5.5.6Always trying something new .... Always failing miserably !!
:edit: misread your post, nevermind
try new ribbon cables, make sure you have UDMA enabled
You must have an agonizingly slow machine, if you cannot burn at 300kbps without buffer underruns. You have to stop executing ALL processes EXCEPT NERO for your machine. This means no movies, no games, no nothing... simply start NERO and walk-away for the time it takes to burn.
From the error messages, it appears that you are trying to copy a CD from one reader to the burner WITHOUT going through the HD. Copy the source to the HD first, then burn from the HD. Slow machines cannot do this (as you were warned by NERO before you started) without a high probability of BUFFER UNDERRUNS (remember these?).
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 13:19 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 01:10 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 15:40 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 14:15
